Hi,
I have one of these,
Star_Note_II_N9770_5_1_inch_Android_4_0_3_1GHz
I am baffled by the storage settings.. when I try to download a file, the browser says, 'insufficient memory' but I thought I had it set to default to 16GB SD??
In 'storage' options, there are two options: USB storage;or SD Card, I have selected 'SD Card'
then beneath that a bar that shows 'internal storage'. What is that? SD or 'USB'? it is less than half full at 503MB. so I guess it is a third storage.
Below that is 'USB' storage which says Total space 2.00GB and has a bar showing about half full
Beneath that is 'SD Card' Total space 14.83GB; available 8.32GB
So, my questions are:
1. All of these show space, so why does my browser think it is full (I can't tell it where to dowload to)
2. If my default write disk is 'SD Card' why is it not storing apps to it? Can it do this, I thought android could now???
3. What does android mean in the option 'default write disk' when it says USB storage or SD Card?? By SD does it actually mean the 'internal' storage?
As you can tell I am VERY confused. Why can't it just have RAM and ROM like the good old days.. lol
Thanks.
Thanks.
