My sd card worked fine till i put an ext3 partition on there. On my laptop it only reads 3gb it which was the part i put on it. I tried to take the part of with same software but it wont show up to adjust it. In my computer i can see and edit the card. I can install zips from the card but on loading the phone no sd card to mount. In recovery i can mount and unmount.
Is it new sd card time.
im runnin muiu all was well but rom manager couldnt put in a part thats why i used pc software.
