My Galaxy S2 won't read my 32gb SD Card?
I just bought an SD card off play.com and the "Mount SD card" area on my settings is just greyed out - I've gone out and bought a card reader and windows recognizes it fine, I then formated it in fat32 but the same problem arises.
Do you have another card you can try to make sure it's not a phone problem? If the card is inserted properly, you should be able to reformat it right in the phone.
