Sdhc card
  • Start date Start date
A
Android Question
Guest
I have installed the verbatim sdhc card into the tablet. Under storage it show up as 29.33 GB but the tablet won't use it to download games. It keeps saying not enough storage. How do I get it to use the SDHC card storage? I formatted the card and still won't pick it up for downloads.
Android downloads to internal storage. You can try using Link2SD to move some parts of some apps to the SD card to free up some internal space. Also move all the files you go to get from a menu choice to the card. Uninstall any apps you're not using (clear their data and cache first). If there are apps you may want some other time, back them up to the SD card. Most backup apps let you choose where the backups go.
