Apps SDK installation problem, NSIS error, installer integrity problem
I just have downloaded a copy of SDK from the android site. But when i
am going to install it its showing an error "installer integrity check
has failed. common cause include incomplete download and damage media.
contact with the installer's author to obtain a new copy."
I have downloaded several times, zip format and exe format. But same
message showing.
Plz help
My PC is win64bit corei3 intel mother board, jdk installed....
Thanks for your reply, actually administrator was not the problem. I downloaded the SDK using firefox and IDM. You need to download SDK by simple download where there is no IDM, antivirus, Firewall activated. I used IE and simple download and was ok.
But now still i am in new problem. I configured this with Netbean.
When i want to start new android project in netban it says "Target android platform must be specified". after clicking on Manage Android SDK option i want to specify the path where SDK installed. i get out from there by clicking OK button.
But when i want to create new android application same case happening.
Hey!
Try opening the directory the installer is on, in your cmd. So then your cmd prompt will be - for example - C:/Users/User/Desktop. So if your installer is in your desktop, then type in androidstudioinstaller/NCRC.
It'll work!
Sorry for the late reply.
