SE Xperia Neo Wifi problem
Heyy.
For some reason my phone won't connect properly to my BT Infinity Wifi. It will connect to it, but then it won't let me use it. It keeps going to the BTFon homepage but then doesn't accept my details. I'm so confused. Anyone know what to do?
There are some very clever sorts that hang out on these forums that can help you. I have to places you will want to check out for help. The first is your device's area of discussion and the second is our general Android discussion area. It's likely you will find the best help through the second link. Thanks for joining and I hope these forums help you resolve your problems.
Sony Ericsson Xperia Neo - Android Forums
Android Lounge - Android Forums
