Hello,
I just went through the specs of the Xperia Pro.
Found out that the ROM is about 320MB and RAM is 512 MB. (Correct me if i am wrong)
And the Pro does not have the "Exemor" sensor (camera) whereas Xperia Arc and Neo both have.
My concern is whether the specs are correct and is the memory enough considering that there are some phones with ROM of about 1.5GB to 8GB and apps that cannot be moved to SD card.
On the positive note the pro has a very good keyboard and the Bravia Mobile engine on a LED backlit screen.
Any info would be great.
Regards,
Kumar.
Regards,
Kumar.
