Search Dialog
awmayhall
Hey guys Im working on a custom dialog box so people can search for their friends in my application. So I have made a custom dialog box containing a list view from a ListActivity, Inside each row their is a image the users avatar and to the right the users name, click on the results the application will take you to their page and what not. What Im actually having problems with is creating a Edit text and a search button ontop of the dialog box so it would look something like this
The Black is the activity running in the background the white is dialog box
a editable text for searching and a search button to initiate the search the results are displayed below in a scroll view with an icon and the username, now i just need to keep the search box only at the top. hers some mock code what im working with
Code:
package com.appsand.proto;
import android.app.Activity;
import android.app.ListActivity;
import android.content.Context;
import android.content.Intent;
import android.graphics.Bitmap;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
import android.view.Window;
import android.widget.ArrayAdapter;
import android.widget.ImageView;
import android.widget.ListView;
import android.widget.TextView;
public class AppSandSearchDialogActivity extends ListActivity
	private static final int TAKE_AVATAR_DEFAULT_GALLERY_REQUEST = 1;
	private static final int TAKE_AVATAR_USER_GALLERY_REQUEST = 2;
	/** Called when the activity is first created. */
	@Override
	public void onCreate(Bundle savedInstanceState)
		requestWindowFeature(Window.FEATURE_NO_TITLE);
		//setContentView(R.layout.general_settings);
		final String[] items =
				"Hello",
				"World",
		class CustomImageAdapter extends ArrayAdapter<String>
			public CustomImageAdapter(Context context, int textViewResourceId, String[] objects)
				super(context, textViewResourceId, objects);
				// TODO Auto-generated constructor stub
			@Override
			public View getView(int position, View convertView, ViewGroup parent)
				// TODO Auto-generated method stub
				// return super.getView(position, convertView, parent);
				View row = convertView;
				if(row==null)
					LayoutInflater inflater=getLayoutInflater();
					row=inflater.inflate(R.layout.search_items, parent, false);
				TextView label=(TextView)row.findViewById(R.id.UsernameResults);
				label.setText(items[position]);
				ImageView icon=(ImageView)row.findViewById(R.id.UserIconResults);
				icon.setImageResource(R.drawable.icon);
				return row;
		setListAdapter(new CustomImageAdapter(AppSandSearchDialogActivity.this, android.R.layout.simple_list_item_1, items));
	@Override
	protected void onListItemClick(ListView l, View v, int position, long id)
		//super.onListItemClick(l, v, position, id);
heres some xml now this just handles the results only, ive trie creating a search.xml its below this one
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="horizontal"
    android:layout_width="wrap_content"
    android:layout_height="wrap_content"
    android:background="@android:color/white">
	<LinearLayout
	    android:paddingTop="10dp"
	    android:paddingLeft="10dp"
	    android:paddingRight="10dp"
	    android:layout_width="fill_parent"
    	<ScrollView
			android:id="@+id/ScrollViewSearchView"
			android:layout_height="fill_parent">
			<LinearLayout
	    		android:layout_height="wrap_content">
				<ImageView
					android:id="@+id/UserIconResults"
					android:src="@drawable/icon"
					android:layout_width="50dp"
					android:layout_height="50dp"/>
				<TextView
					android:id="@+id/UsernameResults"
					android:paddingTop="15dp"
					android:paddingLeft="15dp"
					android:gravity="center_vertical"
					android:layout_gravity="center_horizontal"
					android:textSize="15px"
					android:text="text"
					android:textColor="@android:color/white"/>
			</LinearLayout>
		</ScrollView>
	</LinearLayout>
</LinearLayout>
Code:
<LinearLayout
    android:background="@android:color/black">
	<EditText
		android:text="@+id/EditText01"
		android:id="@+id/EditTextSearchText"
	</EditText>
	<ImageButton
		android:id="@+id/ImageButtonSearchButton"
	</ImageButton>
	<ListView
            android:id="@+id/ListViewResults"
            android:divider="?android:attr/listDivider"
            android:dividerHeight="4px"
            android:layout_alignParentTop="true">
    </ListView>
</LinearLayout>
so this is all just mock stuff but is essentially what im working with,
any ideas on how to do this would be appreciated.
okay so i changed a few things but my biggest thing is getting this xml straight the search box and button are appearing to the left of the results.... heres the new code and heres the xml files
Code:
import android.widget.AdapterView;
public class AppSandSearchDialogActivity extends Activity
	@Override
		setContentView(R.layout.search);
				getResources().getString(R.string.default_avatar),
				getResources().getString(R.string.user_avatar),
			@Override
				if(row==null)
				return row;
		ListView resultsList = (ListView) findViewById(R.id.ListViewResults);
		resultsList.setAdapter(new CustomImageAdapter(AppSandSearchDialogActivity.this, R.layout.search, items));
	resultsList.setOnItemClickListener(new AdapterView.OnItemClickListener()
		public void onItemClick(AdapterView<?> parent,View itemClicked,int position,long id)
base xml
Code:
<LinearLayout
	<LinearLayout
		<EditText
		</EditText>
		<ImageButton
		</ImageButton>
	</LinearLayout>
	<LinearLayout
		<ListView
		</ListView>
	</LinearLayout>
</LinearLayout>
items xml
Code:
<LinearLayout
    <ImageView
	<TextView
		android:text="text"
		android:textColor="@android:color/black"/>
</LinearLayout>
