Searching for GPS
mattywalnuts
It seems every time that I turn on my Gnex screen, the Search for GPS icon is in the notification bar. The only application that I currently keep active that needs GPS is HD Weather Widget and it's set to update every 3 hours.
Anyone else notice that their Gnex is looking for GPS a lot?
Is this because of Google services?
Can I specifically check with applications are using the GPS service?
Thanks!
Hello,
Some apps use GPS you can simply turn your GPS off
If your GPS is draining your battery.
Hello,
I know you can turn off gps...battery is fine. Just wondering if there was a way to actually check which apps are using the gps at that point in time.
