Root Searching for MT ROMS..
lamorsa92
I've been using Android Forums for a few months now, and I have also used XDA Dev. as places to find and try new Motorolla Triumph roms. But, I was wondering if anyone knows of other places to find roms for the Triumph. I don't have any preferences really, although I'd love to find a great ICS rom but it isn't a must have. I've tried Starship, AOKP, CM, MIUI, and surely some others..but if anyone had other sources that I could go to to find reliable roms that would be awesome!
Android Forums is the original forum for ROMS that have been built from source code. IssacJ and Tickerguy were the very first dev's that helped bring CM7 to this phone, and it has been a cascading waterfall since! All other forums that you go to you will find the same user names which are here as well. This is the place for all the ROM's your heart can desire. Agentc13 our moderator has recently updated the ROM list. So check it out and have a flash of a time :)
http://androidforums.com/triumph-al...l-things-root-guide-updated-07-31-2012-a.html
Thanks for the info, that list is amazing! It's good to know that I'm at THE place to find and use ROMS. Also, thanks for your work on CM7 with the 3G fix and everything you guys do! You keep making the android experience better and better! :adore:
