Second lock screen
Recently I turned on my zte zmax pro and it had a second lock screen that said I had to swipe to go to my original lock screen to finnaly open my phone I've locked up why it's happening and people said it had to do with the peel remote app but I do not have that app installed and I have no cleaning or boosting apps which usually comes whit those types of lock screens. If you know how to get rid of it plz help me out. Thanks
Is it still there if you boot into safe mode?
If it is, then it's an update to one of your pre-installed apps that's responsible. If not then it's an app you've installed.
I know that doesn't identify it, but it would narrow it a bit. It certainly looks like the Peel Smart Remote screen, but you say it's not installed so it must be something else using the same junkware.
