Secret ui menu
I've heard that some of it is still available on nougat. I've tried holding down the settings wheel. Even with developer setting changing frame rate to .5 on all 3 things. Not to tech savvy.
Is this menu even available on LG devices?
Yes. Its the thing marshmallow could do. I wanted to see it was still on LG side for nougat.
Ah ok...it very well could be, but I haven't tried it on my LG...I've tried on other makes of devices with some luck.
I could try to look for some codes, but time is short on my end.
Perhaps google dialer codes for your device make/model...some codes may work, some don't.
If you are successful, just be very careful what you change, if anything, it could very well bork your device ;)
Kinda why i aint too curious. I am very new to playing around with settings especially since I have nougat. I wanna play.
Not to get too far off topic, if you want the ultimate in tinkering with your device, root it and start flashing roms/using Xposed/kernel adjustments etc :D
The nice thing about rooting and having a custom recovery is you can use recovery to backup the entire device. If you happen to bork it, you can restore it from the backup :D
Anyway, take it slow with playing/tinkering. Not sure about something? Ask us! ;)
Cheers!
That is why I'm on here to learn about it at mu own pace. Plus I currently don't have a pc. Just my LG and 32 GB sd card
Dialer codes for lg stylo 4
277634#*#
*#546368#*713# for tracfone variant
*#546368#*<last3digitsfromdevicename>#
