Seeking Battery Appy/Widget
Not sure if this exists or not, but I figure I can at least ask the far more knowledgeable people of these forums.
I am currently using Go Locker EX with the Steel Blue theme from TEAM CARBON as well as Go Locker with the "Simple" Theme so I'm not too sure which app brings forth the feature I am looking to get on my main page.
I have attached a screenshot to this posting, I hope I did it correctly.
Anyway, I am LOVING the blue line that shows my battery progress when charging. Was curious if there is an app/widget I can download (don't care if it costs money) that is identical to this. I'd like to have it on my main page (I want it to display the battery percent even when not charging).
Does this exist? If not, no biggie it won't break my heart...
You can do that sort of stuff with minimalistic text. You can have a battery bar like that. It is actually very easy to do.
You have a few options. I haven't tried these market apps below but they have great reviews and look like they will work.
1. Try either T.E.A.M. battery bar or charge bar from the market (play store).
2. Since you are rocking an EVO (great choice by the way), you could install the latest MikG ROM. All of the 3.x versions include a setting to enable the MIUI battery bar. Plus it is just a fantastic ROM and you should be running it anyway.
3. If you are feeling adventurous you could make smali changes to SystemUI.apk and enable this yourself:
http://forum.xda-developers.com/showthread.php?t=1371330
