Seeking N7000 ROM recommendation
PeteCress
My N7000`s instance of 4.1.2 keeps spontaneously uninstalling apps.
At first it seemed to be only one app that I don't use all that much, but today I was out in the middle of nowhere and discovered it had uninstalled all 3 of my map/navigation apps.
My understanding is that this is a known bug in 4.1.2.
Making sure apps are installed on internal memory is said to help, but is not helping in this case.
The device is rooted. My intent when rooting was not to try other ROMs, but just to have the convenience of things like the ability to change User Agent in Chrome and list WiFi connection parms.
But now it seems like time to take the next step...
Does anybody have a recommendation for a ROM that does not have the App-Uninstall bug?
The GN was rushed out the door, by Samsung, with many problems.
Random deleting, of apps, is not one of them.
I suspect that you have a rouge verson of busybox running on your phone placed there by whatever tool you used to root your phone. In other words malware.
I have 4.12 and I have offline navigation. I use it when I travel without any problems.
Pick just about any ROM and flash it onto your phone. I bet your problem will go away.
