Seidio 3500 battery and case with leather belt holster
shanboxer
I'm thinking about getting the 3500 battery from seidIo for my Htc evo but want to see if anyone knows if there is a case that can be used with it and more importantly a leather belt clip holster that I can put the bigger 3500 unit in. I want to make sure I can carry it on my belt as I do now but need to make sure there is a leather case out there that will take the added size. Thanks for your help!
Seidio makes a case that fits over the bigger battery door. They also make a clip that should still work with the extended battery
