Accessories Seidio 3500 Extended Battery
From using a Droid with the 2800 mAh pregnant pack on my phone...lol:
This looks like it wont be as bad as mine. Looking at the side pics u can tell it will be noticeable tho. Mine is shorter so the weight affects my phone more. One advantage u might not notice if u get it:
Holding it in landscape mode felt better. Your fingers can rest beside the battery and can give u more sturdy control. Its nice when gaming. This one is made different than the one for the Droid but it should be similar when holding the phone landscape.
Does the Seidio battery run hot? I have heard complaints about it running much hotter than other extended batteries.
-Sev
Seidio 3500 impressions along with 2600.
1. You usually get what you pay for (this battery rocks) and the 2600 did not.
2. The 2600 I had was junk. Cell charge retention depleted to about half it's life within a week (about equal to 1300 stock).
3. The 3500 is a beast in a good way.
4. I still think $63 is too much for a battery, but I go back to item 1.
5. The cover/door is sturdy and built well (for plastic).
I will not bother trying to equate use, since too subjective, but I use the heck out of my Inc for surfing, games, videos and MP3, and this puppy lasts the day and still has 60%. The 1750 had a little juice left at the end of the day, so the 3500 seems to correlate to 2X or better than the 1750. It seems like more than 2X, but again, usage is too subjective to peg it.
If you use the heck out of your Inc, the Seidio 3500 is a good buy. Then again, if you do not mind carrying extra batteries and restarting, there are cheaper options. I do not like carrying extra batteries and restarting. I will keep the 1750 as a backup when I travel, though.
