Accessories Seidio Battery Dock & HTC OEM Charger Under $21 Bucks!!
Am I reading it wrong? It looks like you only get a "battery dock" for $12, but requires the actual battery charger ($30) for it to be of any use.
Yes, you are reading it wrong. Kiz reported the purchase of the additional Battery for $31, not the charger.
Multi-Function Battery Charger (Sold Separately) required
Expand your Multi-Function Battery Charger to use with additional Smartphones with this accessory kit.
- Includes battery charging plate and device charging cable
- Works with standard and extended batteries
*Multi-Function Battery Charger required
I have that dock. U need the actual battery charger or the dock won't work. The charger comes with dock so no need to order both.
Yes ONLY the battery dock a charger is required.
An HTC OEM charger can be bought off Ebay for $8.95.
Dock $12.00
OEM Charger (off Ebay) $8.95
an htc charger isn't going to work with what you bought. the "dock" is just a plate that attaches to this charger. now you may be able to find that on ebay, but if you just bought a regular htc ac adapter and the plate, that ain't workin'.
What kind of connection is on that dock? USB or micro USB?
The above mentioned link to the charger is a one sided USB and one sided micro USB correct?
If so there plugging the micro side into the unpowered dock correct?
Ill have all the parts next week and update the thread, heck it was only $21.00
