Demonking07
Hi guys.
So I got a nexus 7 a couple of days ago. And after using it for a while it froze. I tried to reboot to no avail. Then I went into recovery mode and tried to do a hard reset but again, it makes no progress.
So I downloaded the SDK kit aswell as the nexus 7 root toolkit. But I can't make and progress because I did'nt have usb debugging enabled.
When I try restoring via the root toolkit, I get fastboot "locked" errors.
Is there any way to unlock fastboot without access to the nexus' setting menu? Since I can't turn the thing on.
Also, upon loading the root tool kit I get an "adb outdated" error.
Is there anything I can do to fix my Nexus that would not require Usb debugging enabled?
Many thanks for any help you can provide.
D.K
D.K
