you can also press and hold the number u want to send a sms to and a popup menu will appear with several options, including send sms
I've tried this before, but the text always gets kicked back to me saying i need to enter the 10 digit number (it adds a 1 in front of everything). Any ideas?
Are you able to send texts to 10 digit numbers....even though they are local? - Yes
Have you only tried using the default Messaging program? - Yes.
