Send Text to Group with GoSMS
QinCT
Just looking for step by step instructions--new to android and need to send texts to groups for my job. Would rather not have to select from contacts every time as required by stock app. Thanks for any help!
Welcome to the forums QinCT, glad to have you here :)
Hopefully i can try and assist you with the issues you are having today!
Using alternate messaging apps like Go SMS Pro make group messaging easy.
By following these steps:
Once you have the app downloaded and on your phone, open the app GOSMS Pro. Click menu and then settings. In settings, click application settings. There should be an option (3 down) called message grouping. Make sure that box is checked. After you do this, it should push all the future group messages into a single thread. I think it only does this if the messages are received with in a certain amount of time of each other, but I'm not certain on that.
Otherwise check out this app: GroupMe
Hope this helps and thanks for joining :D
