Help Send to sd card not working
rickey2
I cant get send to sd card app to send to sd card. Lg g stylo 5.1.1. This app used to work fine with 4.2. What happened?
Android KitKat happened
This is from the app developer's web page
KITKAT NOTICE
In Android KitKat is not legally possible to write files to any location on external SD card. So the functionality of the app limits to internal storage on KitKat. If you have a rooted device you can try a fix: https://play.google.com/store/apps/details?id=nextapp.sdfix
Please note that "Send to SD card" cannot send applications to SD card by itself. It can only save files which are sent by another applications.
For details see http://code.google.com/p/sendtosd-android/wiki/FAQ
