Help Send to Voicemail
Hi All, i recently upgraded from the G1 to the Galaxy S in the UK.
on the G1 you can set a contact to automatically be sent to voicemail via a tick box in their contact details. I though this was an android feature, but I cant find it in the same location on the Galaxy S (i9000).
I have seen that there are apps that can do this, but does anyone know if this is an oversight by Samsung and will be there later, or if this was just a G1 thing?
thanks
John.
here is the answer
Set auto rejection
Use auto rejection to reject calls from certain numbers automatically. To activate auto rejection and set up the reject list,
1.
In Idle mode, open the application list and select Settings → Call settings → All calls → Auto reject.
2.
Select Enable auto reject to activate auto rejection.
3.
Select Auto reject list.
4.
Press [ ] → Create.
5.
Enter a number to reject and select Save.
6.
To add more numbers, repeat steps 4-5.
