Hi Guys.
I had an odd thing occuring the other day. Everytime I sent an email via the preinstalled email app on my note, I was getting Connection Error and Sending Failed Null appearing on the screen, but the actual email appeared to be being sent!
It was becoming very irritating, as it was happening automatically also so i'd be getting it appearing when using other apps.
I did a bit of research and couldn't find much useful info online, apart from that others seemed also to have this problem.
RESOLUTION:
Remove the email accounts and then re.add them. This worked fine.
As I am using GMAIL this worked a treat, all the contacts and emails came right back up again.
Of course if you are using other systems , back up your emails and contacts, as applicable.
I am not quite sure what the problem was to start with , but I think it's to do with sending replies to receipt requests from senders. I never usually send these replies, but remember just prior to this problem I was in a hurry and clicked OK to a few of them instead of CANCEL; maybe the data was trying to be sent via some other system and got corrupted. I don't know....
Anyhow the above certainly fixed it for me. Hope it helps others.
RESOLUTION:
