Help Sending Text
Matty527
Newbie here, when getting a text that has been sent to multiple people, how do I reply to the sender only ? Is there a setting for this ? I never use "Reply-All" on anything. Also, is there a way to change your Homescreen Clock ? the one that comes on when you hit the power button. Thanks in advance.
The reply all feature to text messages ticks me off. I have not been able to figure out a way around it.
Search "go locker" in the market. It'll do what you want.
From the message with a "group" of recipients, Menu hardkey -> More -> Modify recipients. Then you can delete all the recipients except those you want to receive the response ... or add more if you wish.
I hate the group thread option on a text. You should have to turn that on per text. Not have it on as a factory setting. It is so annoying. I turned mine off permanently. All others should do the same as a common courtesy.
How, prey tell, is that done.
