Help Sensation XE Driver problem??
Hello,
just made an account for this, because i can't find an answer.
so yeah. I saw yesterday the update, and started it. Left the mobile, and when i came back i saw the line was full, so like 100% but nothing happened. It stayed so for like 20 minutes and i took out the battery and put it back in. The phone start but stays on the firt white screen and is only says 'htc' in green. Tried taking out the battery a few times but nothing helped. Then i wanted to connect to the computer (win7 if it does matter) and the pc started to '' recognize'' the phone and started to check if it can be used. (you know like when you plug it in to transfer files and stuff). But then it said '' no driver found'' i clicked ok and it disappeared. unplug and plug in and then it said ''installing drivers''. it was like almost done but then my phone like plug itself out. i didn't touched the cable from the phone to my pc. so the installing was failed. i tried again, but nothing happens. I hear the sound when i plug it in but nothing happens, so i can't start my phone now, and my pc does nothing.
Any tips what i could do?
Sorry for the long story but i think i explained everything allright.
any comment is welcome
