Root Sensation_4.4.2-Deodexed
Jaay Dogg
Android Expert
This is a fully deodexed 4.4.2 rom
De-Sprinted, Removed Spark UI
De-Bloated, Added Quicksettings in pulldown
Fixed boot animations
Works on all Sprint MNVO’s
Added: pattyboi’s Awesome Kernel
Added: Reboot Menu App, Beats Audio, Viper FX, Shady File Manager, Root Explorer, MSL reader, Download All Files, Root Uninstaller Pro, Xposed Framework Installer.
Known Bugs: Stock Messaging app force closes, But 3rd party app will fix issue.
Wipe system, data, cache, & internel storage then flash sensation zip & reboot takes a couple min so be patient.
Sensation 4.4.2 Deodexed Rom link: https://drive.google.com/file/d/0B6Zc5KcWFHSkV0xoakVFR0I1Wmc/view?usp=sharing
sorry for all the questions but im new to all of this, but i forgot to do a back up :( and now my 4g wont work can anyone please help me :(
theoretically mopedryders Universal APN fix should if flashed correctly fix any problems you have with both 4G and MMS/SMS. sorry for not posting a link. Just do a quick search in the unofficial cyanogen 11 forum for the HTC 510.
attached is the file referenced previously.this should fix any problems that you are having with MMS or 4G. just flash and go. One little side note, I believe that you must use either Google Hangouts as your stock sms app or textra. I have tried it on a few others but can't seem to get everything to work. It's worth a shot.
