separate ringtone for separate mails
dhongdhong
In gmail apps how do I set separate notification sound for mails coming from specific mail id ?
if its not possible in gmail apps then which other app can fulfill this requirement ?
OS: Android 4.0.4
I'm not sure how well this works, but I've just played around with Gmail settings an by the looks of things you can (you'll need to setup labels though).
If you open Gmail, go Settings -> Account Name -> Mange Labels -> Select the labels you want to Sync, there's an option there to set individual notification tones
