Help serious reaction problems
TheAlp
i have suddenly got some weird problems that i have never had before,
when i click play or any other button on my bluetooth headset it takes about 30 if not more before something happens, i can press pause, turn off the headset and then a minute after it stops playing, same problems with music widgets, if i try to open the player it takes about a minute before it reacts and when it does it overwrites anything else i'm doing even if the phone is locked it starts up, it seems i have the same problem with some other widgets mainly those for changing settings, its not really lag like where the whole phone becomes slow,
anyone who got a way to solve this?
i have already turned on USB Debugging which helped but doesn't anymore and the battery uses more power than it use to (went from 15% used by the system to 66%) which means that i would normally have around 70% left at this point of the day but today i only have 40%,
it is really making the phone hard to use, never had any problems before this that couldn't be solved by turning on USB Debugging.
Hope someone can help me.
edit: right after writing this post it seemed the lag problems are gone, might be when i play music, not really sure, if anyone have tried anything like this please comment anyway.
-edit: happened again, really not sure whats causing it.
