Root Sero 7 pro root starters
very easy to root with the above mentioned tool. I believe the same author made a ROM for the sero
I've have my sero 7 pro rooted for a few weeks now with xboxexperts tools and I have not had a single issue. His tabletui and battery mods are great additions. His tools are the only one's that have been 100% accurate for me. Donate to his girls college fund like I did to thank him. He earned it with product.
Hello
I have a problem to root the tablet.
First: I have Windows XP 32 bits.
I haven't installed any SDK Android package so far. It may be why it doesn't work !! but let's wait your answers first.
Impossible to install the ADB driver of xboxexpert.
I succeed in installing a "standard ADB driver" I found on the net.
After, when I execute the file from xboxexpert:
But the root process does not work:[*] Waiting for device...
* daemon not running. starting it now on port 5037 *
* daemon started successfully *[*] Device found.[*] Pushing exploit...
cannot stat 'pwn': No such file or directory
Unable to chmod /data/local/tmp/pwn: No such file or directory[*] Pushing root tools...
1149 KB/s (91980 bytes in 0.078s)
1823 KB/s (1867568 bytes in 1.000s)
1893 KB/s (969701 bytes in 0.500s)
pkg: /data/local/tmp/Superuser.apk
Failure [INSTALL_FAILED_ALREADY_EXISTS][*] Rooting device
/system/bin/sh: /data/local/tmp/pwn: not found[*] Cleaning up...
rm failed for /data/local/tmp/pwn, No such file or directory[*] Exploit complete. Rebooting device.[*] Waiting for device...
* daemon started successfully *[*] Flashing CWM Touch Recovery!
1740 KB/s (7045120 bytes in 3.953s)
/system/bin/sh: su: not found[*] All Done! Final reboot!
At the end, the tablet is still not rooted.
Tonight I will try to install the Android SDK package.
Thank you for your help.
I ran xboxexpert's latest all-in-one and while I am rooted, recovery seems to be the standard one, not CWM Touch.
Sam
I also noticed another user posted about this as well over on xda but was never responded to.
I'm running xboxexpert's file from a Win8 pc if that makes any difference.
Sam
Got Touch Recovery to install by booting into Fastboot and running XERecovery.exe. It installed CWMTouch and it asked me upon exiting if I wanted it to prevent the stock recovery from reinstalling/flashing. Said yes and now it boots into Touch Recovery fine. Now to install xboxexpert's custom rom.
Sam
Sam
I launched FASTBOOT. But the screen just shows that with no options. If I plug in the USB cable and try to run XERecovery.exe, the cmd console dialog opens device manager. Unlike when I first rooted, the Sero doesn't appear??
I aborted the operation and rebooted. I still have root as Super User shows the 3 programs I've allowed access :FolderMount. Clean Sweep and ES File Explorer. Any clue what is wrong?
PS-I followed post 2 in Developer's thread again, ignoring Sero not appearing in device mgr. I ran XERecovery and now have CWM. Everything is copasetic and instructions there are right on!
