Root SetCPU Settings
jradicle11
That Guy
I want to use SetCPU to increase battery life but I'm pretty lost on what my settings should be and which profiles to use.
Anyone have some recommended settings?
My settings, in order of priority:
Temp > 42C 600/300
Screen off 600/300
Charging/Full 1200/300
Charging AC 1000/300 (to offset the heat created by charging)
Battery < 16% 600/300
Battery < 21% 800/300
Battery < 41% 1000/300
Remember the phones only report battery level in 10% increments down to 20%, and 5% from there on out, that's why all my settings are 1% high.
It won't let me go back 1gHz. Oh well, I don't need to go any higher.
Thanks for those, I just made mine the same. Hopefully I'll see an increase in battery life.
If you overclock your CPU, then go into SetCPU make a overclocked setting, you will be set.
@NiceGuysFinishLast - Just wanted to send you a thanks for the recommended settings. I just set mine the same for a starting point. How are those settings working out for you? Have you made any changes?
