Root setCPU undervolt question
Does anyone have the setCPU app? I was wondering if it has the undervolting tap.
I undervolting saves battery so I would possibly buy the app ($2) if this feature is available for the commando.
If you can undervolt the commando how hard is it to do? Just a setting tweek from the app or is the files that need to be replace on the phone first?
Has anyone done this yet?
I have never been able to adjust the CPU of the commando, only able to change the governor so it stays on at 806MHz
The only way to adjust cpu or over clock or under volt is to build a custom kernel. It has to be built into the kernel.
