Help Setting contact notification for texts
dakotanut
On my note 2 I could set a notification for ring tones and texts for each contact. It could be 2 different tones. Can't figure it out on the note 4. Any suggestions?
I am running a custom ROM, so I hope this applies to the stock Note 4:
Go to the contact and hit the "EDIT" (pencil) icon.
Scroll to the bottom... there should be a "Ringtone" option. If you don't see it, try pressing "Add another field" and see if "Ringtone" is hiding in there.
There you can set the ringtone for that contact.
Hope this helps. If it doesn't, let us know :)
