A Android Question Guest Jun 23, 2016 #1 this may sound crazy but hoe do you set default apps in the s7 such as photos, sd card. gone to settings apps manager but wont let me change.
lunatic59 Moderati ergo sum Moderator Jun 23, 2016 #2 Not sure if it's the same on the S7 but on my Note it's right under Application manager on the general tab. "Default Applications." If they changed that for 6.0 then try going to menu>settings>apps and then pressing the menu key for advanced options.
K KOLIO Guest Jun 23, 2016 #3 Android Question said: this may sound crazy but hoe do you set default apps in the s7 such as photos, sd card. gone to settings apps manager but wont let me change. Click to expand... lunatic59 said: Not sure if it's the same on the S7 but on my Note it's right under Application manager on the general tab. "Default Applications." If they changed that for 6.0 then try going to menu>settings>apps and then pressing the menu key for advanced options. Click to expand... Samsung screwed up defaults in the worst way,at least on the Note5 & I suspect the S6/Edge as well,& all their phones thereafter. Try this app (or other similar apps in the store),it takes it back to where you have better control of defaults: https://play.google.com/store/apps/details?id=com.aboutmycode.betteropenwith&hl=en
