Setting priority for notification on Android 2.3
cdysthe
Member
Hi,
I know you can set priority for notifications on android 4.x, but I have a 2.3 based phone where I need a certain notificaion icon to stay on screen and not be pushed out by higher priority apps. The phone is rooted. Is there are way, an app maybe, that can be used to make sure notification from a certain program is set high so it's not pushed off screen?
Im not sure but i think you can prioritise notifications with the Light Flow app. Try the free version (limited app support) first :thumbup:
