Help Setting SD card/extsdcard as default
cheggerspop
Folks,
Whilst tinkering with my S3 the other day I came across an option to set my Kingston SD card (extsdcard) as the default location for saving data.
I didn't click it (for some reason!) and now I can't for the life of me find it.
Can anyone give advice on where it is.
Cheers,
Chegs.
Folks,
Cheers,
Chegs.
Did you ever get an answer to your question?
was this a setting within the camera? as I believe that the default is the internal storage but one of the options on the Gears / Cog icon is to change this to SD Card.
