Help Setting txts to vibrate? halp!
Been through the menu more then 4 times...I cant figure this out. Ide like my txts to vibrate when they come into my phone both when the phones on loud and vibrate. Where is the setting for this?? thanks.
whatever app or stock text app ur using u should just go into menu>settings>notifications and there should be a check box for vibrate.
The default text application installed when you purchased your device will have the options available as @buck shot stated. However, the Handscent application (which just went to version 3.0 yesterday) has advanced options for notifications [one is vibrate, and vibrate re-alert].
