Help Setting up Nexus 4 to work with metro pcs.
I just bought a Nexus 4 and I'd like to activate it on Metro PCS. I inserted the sim card thinking it would work but it doesn't. I read on various sites that it does work since Metro PCS is on T-Mobiles network. So how do i set up so it can work to make calls and stuff?
You would need to make sure you have a GSM Metro PCS SIM (some Metro PCS SIMs are 4G LTE CDMA SIMs and not GSM), then contact Metro PCS for their APN information or try this from another forum:
here are my Metro GSM Galaxy S4 VPN settings from factory, hope they serve you:
APN Settings:
Name:
MetroPCS
APN:
fast.metropcs.com
Proxy:
Not set
Port:
Not set
User Name:
Not set
Password:
Not set
Server:
Not set
MMSC:
http://metropcs.mmsmvno.com/mms/wapenc
MMS Proxy:
Not set
MMS Port:
Not set
MCC:
310
MNC:
260
Authentication type:
None
APN type:
default,mms,supl
APN protocol:
IPv4
APN roaming protocol:
IPv4
Enable/disable APN:
APN enabled
Bearer:
Unspecified
Also remember you need to activate the SIM with MetroPCS before it will work.
