when you insert the sim the phone will tell you to reboot. I think when it turns back on the apn settings page will come up and you have to enter the apn info. If it doesn't you can go into the phone settings to enter it. You get the apn info from the phone carrier's website (in my case it was straight talk with an AT&T sim).
I set up wifi days before I even had my sim card so I know that should not cause any issues.
Thanks to all. While lengthy due to porting numbers from multiple phones, process was smooth at the att store. Did not have to mess with APN...factory defaults worked. Now up and running with this awesome phone.
Of course, getting ready to unlock the boot loader... but that will be a topic for a different post ... hopefully not one crying for help!
