Settings for GoLauncher
Vixer
Member
GoLauncher is still my favorite launcher application, but.....
I do not like the way they split out the settings into different areas. It was great when you could access and assign all of the possible settings by just pressing the menu button.
It seems like I have to search a lot of places to locate the setting I want to change.
You can access all settings by going to menu>preferences. Everything is still there.
The setting I am looking for is the one where you can select what type of effect is used when you press the power button. I remember one of the types you could choose from was TV. For the life of me I cannot find where that setting is made now.
Thanks.
Are you sure it was Go? I've used Go for over the past year and I've never seen that option. I remember I had to download a different app just to have that.
