Help Settings for no internet, keeping MMS
Hey all.
Just got my Galaxy S (on AT&T) and am still trying to get everything set up and optimized.
I have a limited data plan, so I'm using APNdroid to block connections. I also have 'Data Network Mode' deactivated (by holding the power button and selecting it).
Under APNdroid I have All APNs disabled, 3G Disabled, and MMS enabled.
One of these settings is disabling MMS messaging, and I can't figure out which one(s) are doing it. Maybe a combination? I'd just like to disable data but still be able to MMS.
I'm running Froyo 2.2, if that matters. And I'm open to other apps then APNdroid if you'd recommend a different one!
Thanks again!
