Already tried factory reset and cashe clean. Just got a tab 3 and can't connect to WiFi tried to open settings and it says unfortunately touchwiz home has stopped. Cant login to google account or anything. Any suggestions?
A Factory Reset will clean out your Tab's user partition but it won't affect anything in the separate system partitions. TouchWiz will be hiding in one of those system partitions.
You could try at reset TouchWiz by going into your Settings >> Application manager, slide over to the 'ALL' category, scroll way down through the listing until you find TouchWiz home, and tap on it. Tap on the 'Force stop' button, then tap on the 'Clear data' button (that will wipe its settings and app cache), and restart your Tab (so TouchWiz restarts).
Could you give some more details so there's context as to what's happening? That string of text indicates a web error so is it popping up on a browser window or some app? Also is all one continuous line as you typed:
siteerror404.000webhost.com/cpu-limit-reached.html
or is it, '...site error...'
Did you get your issue with TouchWiz straightened out?
