Several Problems - your assistance please
Allthunbs
I have Just purchased a used Samsung Galaxy Sii, i9100m
On the screen is a program called "Torch". I want to use another program. How do I remove "Torch" from my mobile?
I refer to the manual and I'm supposed to have an icon and program for "Youtube" but I can't find it anywhere. Where do I get it or find it?
I originally thought I was buying an i9100 but instead found (too late) that I'd purchased an i9100m. There is no radio, that I can find. Is there some way that I can activate the radio?
Thanks for the help. I'm sure there will be more to come.
Allthunbs
Sounds like you have cyanogen mod as your os.
You can get YouTube from the play store.
Having torch installed won't prevent you from using another app to do the same thing. If it is cm then torch is a system app and won't be taking up any user space.
