kalaster
As of recently (past few days) I've noticed horrendous battery life. So bad in fact, that my phone will not last 4 hours after a full charge
Also noticed that the phone is a bit too hot for being in idle. Running Stock 4.3 not rooted.
So figured something was running in the background, at first glance i notice the android OS was at the top of the battery list at a whopping 37%!!
So the past few days i've been googleing this issue and im not the only one. Come to find out, disabling location services in settings revealed that the culprit may be from Google services. Though disabling location access doesn't solve my issue, it adds Google Services to the top of battery list, using up 50%. I've searching for days and trying various methods, some worked temporarily for the first time, but never solved the issue. I even went as far as a factory reset which solved it for about 3 hours, and STILL this problem persists.
I'm at a loss guys, i've tried researching but nothing seems to work. I use my phone daily for work and i need to figure out a solution ASAP. any ideas?
