Help SGH-I337 Stuck In Recovery Boot Loop
  • Thread starter Thread starter Jesse Adkins
  • Start date Start date
  • Tags Tags
    at&t
J
Jesse Adkins
Guest
So I tried to downgrade my Galaxy S4 from 5.1 to root it, but I forgot to enable USB Debugging before I did. When I tried to use ODIN to flash the downgraded ROM and it failed, I ended up on the screen that says "Firmware Upgrade Encountered an Issue". After some research and tinkering I was able to re-partition my phone, but now it is stuck in a bootloop, only able to boot into stock recovery or download mode. Is there anything I can do to fix it?
I thought 5.0 OK2 was the current firmware for the i337. The firmware you linked to should have worked. Is there a new update?
I'm pretty sure it was 5.1, though it may have been 5.0.1. It should have worked, but I made the mistake of forgetting to turn on USB Debugging, so that's probably why it didn't work
<ID:0/004> Added!!
<ID:0/004> Odin v.3 engine (ID:4)..
<ID:0/004> File analysis..
<ID:0/004> SetupConnection..
<ID:0/004> Initialzation..
<ID:0/004> Set PIT file..
<ID:0/004> DO NOT TURN OFF TARGET!!
<ID:0/004> Get PIT for mapping..
<ID:0/004> Firmware update start..
<ID:0/004> sbl1.mbn
<ID:0/004> NAND Write Start!!
<ID:0/004> sbl2.mbn
<ID:0/004> sbl3.mbn
<ID:0/004> rpm.mbn
<ID:0/004> aboot.mbn
<ID:0/004> tz.mbn
<ID:0/004> boot.img
<ID:0/004> recovery.img
<ID:0/004> persdata.img.ext4
<ID:0/004> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
I wonder if you got a bad download. I have used those files before without issue.
You could try downloading again.
Still failed. This is what the Message box showed
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> I337UCUFNB1_TWRootable_Full_Odin.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/004> sbl1.mbn
<ID:0/004> sbl2.mbn
<ID:0/004> sbl3.mbn
<ID:0/004> rpm.mbn
<ID:0/004> tz.mbn
<ID:0/004> boot.img
<ID:0/004> system.img.ext4
