Shabbypenguin,
My SGH-T399 is currently in a state where it will not update anything using ODIN. I have tried just going back to stock so i can start fresh - but odin just keeps saying failed after "SetupConnection.." is displayed for 10's of minutes
Do you have any thoughts on this?
Currently I am putting the unzipped SGH-T399-Stock-MJA file into the "PDA" field in the provided ODIN.. and it is just failing after about a half hour of sitting on "SetupConnection..."
Right now it is Rooted using your OdinExcution v1.81 for root.
But I cannot get unrooted.
try a different usb port, usb cable and if those dont work try some new drivers. it sounds crazy but some cables just dont have thje means to work with odin as well. dunno why :/
So if I use ShabbyPenguin's one-click root, how exactly would I unroot? I'm still a bit confused? Just do the same steps with the the unrooted kernel? Thanks.unless you repartition the pit should never change, since odin pulls the pit from the phone before flashing it should be fine. until you click repartition and format your device.
