SGH-T959V 2.3.6 Plus ROOT. I did not make this. I found this link on XDA.
I have used it on 4 different SGH-T959V devices with 0 issues..
this is for T-Mobile phones.
Read the dam read me before posting shit like this don't work how do I do this etc etc.. I will not answer any questions related to those issues. If you can not read a read me then you deserve no answer
If you do not know how to get into download mode then do not even try this..
If you brick your phone then to bad that is the chance you will take when messing with your device.
Here is the READ ME FIRST..
___________
Tools to update your Samsung Galaxy S 4G to GB 2.3.6 and root it.
1) Install phone drivers on your 64-bit Windows machine
2) Install Odin
3) Restart phone in Upload Mode and connect to USB
4) Load GB Rom to 'PDA' in Odin and press start
5) Restart phone in Upload Mode and connect to USB
6) Load 1st Root Rom to 'PDA' in Odin and press start
(phone will be in boot loop after this step. Do a battery pull and)
7) Restart phone in Upload Mode and connect to USB
8) Load 2nd Root Rom in Odin and press start
This will update your Samsung Galaxy S 4G to GB 2.3.6 and root it.
Disconnect your phone if it
___________
2) Install Odin
