Hi,
I followed a guide (How to Upgrade Samsung Galaxy S to Android 2.2 Froyo | Gadget News) to upgrade my firmware to froyo.
The rooting went fine, but when I tried to upgrade I encountered a problem. I did everything as explained in the guide: Pointed to all the correct files for "PDA", "PHONE" and "CSC" in Odin and I did tick the "Re-Partition" option. With my phone I booted into download mode and connected it to the computer. Clicked start in Odin and got the following printout:
<ID:0/010> Added!!
<ID:0/010> Odin v.3 engine (ID:10)..
<ID:0/010> File analysis..
<ID:0/010> Set PIT file..
<ID:0/010> DO NOT TURN OFF TARGET!!
It got stuck there so I left it hoping its just taking a little bit of time...however, after an hour's wait I figured the upgrade was not successful.
I wasnt sure how to cancel the upgrade, so i looked on the web and apparently I was suppose to remove my battery for about 5 minutes or so and then put it back in and it should be okay...I did that, but now my phone doesnt startup at all. It just shows a picture of a cellphone trying to connect to a desktop pc but with an exclamation mark in the middle of the connection indicating that it cannot connect or something. Tried to plug the phone into my computer again and tried using ADB to reboot it again, but adb can no longer see my device.
If anybody can help, please do? Getting a bit desperate here :| And reeaalllly wanna upgrade to froyo. T_T
Thanks
<ID:0/010> Added!!
Thanks
also try using Odin3 v1.3)
