Help SGS2 not sync'ing with Gmail calendar (Pure Calendar Widget)
4ngi3
I have gone from a HTC Desire to a SGS2. With my Desire, I used the stock calendar widget and everytime I updated teh calendar from the phone it would update on my gmail calendar and vice versa.
However, as there is no similar stock calendar widget on the GS2, I have downloaded Pure Calendar Widget and it looks great, but when I add a calendar item on gmail on my laptop, it doesn't sync on my phone. Even after I press the refresh icon on the phone.
Is there a setup option that I've missed?
I had a problem with this. My calender app would just not sync at all with google calender, tried every option I could to get it to work. In the end I had to do factory reset and it worked after that. Try clearing the data in the calander app, didnt work for me but might do for you.
Good call mate, mine's been working fine, moved some work shifts forward online and then re-synced my calendar and couldn't get it back.
Cleared the data, resynced and now fine. Bang tidy. :)
