Help SGS3 Charging Problems
wzup
Hey guys,
Since 3 days my SGS3 doesn't charge properly. If I turn it off it's about 10% per hour. And if I'm using it the battery discharges.
Have you ever heard about this problem?
I'm using Android 4.1.2 with the newest Siyah Kernel... I tried to flash an other Kernel but it was the same...
Thanks!
wzup
Download the STweaks app to control siyah kernels. In "misc" settings you can increase the charge current. You can also disable the safety thing that makes the phone charge slow when it thinks youre using a faulty charger (at your own risk lol) :thumbup:
(Have u tried another charger btw?)
thanks, but stweaks is already installed and my charging currents are 1200 for AC and 700 for USB...
