Shabbypenguin
Extreme Android User
Presents:
Metropolis Rom 1.5.0
Screenshots will be posted here
Downloads are in #3 Addons/Themes will be in post 2
Instructions:
Download rom (derp)
copy to your phone (internal or external sdcard)
Boot into recovery (power + vol up + home til you see blue text in teh top left corner)
TWRP go into the wipe menu and choose factory reset (no matter what rom you are coming from)
CWM choose wipe data/factory reset on the main menu
Flash the rom normally
Versions:
1.5.0
Rebased on NA1
Knox free
Should have gotten most if not all the bloat, lemme know if i missed any.
Got something special now, check out post #2
Previous versions:
1.4.0
Based on MF2
Removed some bloat (mostly annoying metro apps)
Bootanimation support
Init.d
updated supersu to 1.41 and busybox to 1.20.2
Youtube HD inverted
1.3.0
Fresh slate starting from MD3 premium suite upgrade
1.2.0
Added Arocker's 4 way reboot mod
Added Note 2 camera/gallery
Added the public beta of the wallpaper app, it needs more wallpapers (original submissions only people i can google myself ) and a proper name, as it isnt really my wallpapers
Added Multiview support (thanks to gruesomewolf, edgeez25, and Arocker)
Changed sh to bash for a better shell experience
Removed the custom bootanimation and sound i spent hours working on because people couldnt figure out how to remove it and/or swap it out themselves. get used to see this flashing android logo as its obviously not worth my effort to try to make my rom custom.
1.1.0
Rebased on MB2 (4.1.2 official)
Deodex'd/zipaligned
Pop up browser added
Init.d Support
Custom bootsound
1.0.5
fresh start based off leaked LL1 rom (4.1.2)
1.0.4
Custom power on song
Custom bootanimation
Bootanimations are done properly so should fix dual core bug, hopefully...
1.0.3
Actual bootsplash screen custom made by myself
Fixed updater script so its a bit smarter
Note II popup browser
Fixed gallery flickers
1.0.2
added init.d support
insecured kernel (adb runs as root)
boot animation support
1.0.1
broken
1.0.0
Based off leaked MetroPCS jellybean build
0.0.5 Public release
0.0.1 Initial version
baseline rom
Based on MF2
Init.d
Youtube HD inverted
1.3.0
1.2.0
1.1.0
Deodex'd/zipaligned
Init.d Support
Custom bootsound
1.0.5
1.0.4
1.0.3
1.0.2
1.0.1
broken
1.0.0
baseline rom
